Old 07-15-2019, 06:16 PM   #15
RMcG
Drives: Yaris manufactured after 2007
Originally Posted by johnwk View Post
It wouldn't hurt to run a few gallons of distilled water through the system (following the same drain-fill-drive-drain procedure) before filling it with the new coolant.
A mini-tip: I found that only unscrewing the radiator drain plug part of the way prevented it from spraying all over the plastic under-engine guard (where it will collect and sit).
If I do decide to run distilled water through the system, how long should I let the system run in order to mix & help get the older coolant out of the system? Ten minutes? 20 minutes? Until the engine is hot?
(I know that there is the potential problem of diluting the coolant, since you cannot get all the distilled water rinse out of the system before you add the new coolant.)
Thanks,
R.
RMcG is offline   Reply With Quote
Tags
change, coolant, engine
AT fluid change earlier than 100k miles hw6515 DIY / Maintenance / Service 25 06-06-2014 01:54 PM
HELP! Coolant is rusty brown only 30K! TheSilkySmooth DIY / Maintenance / Service 25 05-27-2010 08:26 AM
