Old 07-15-2019, 09:31 PM   #1
johnwk
Drives: 2010 Yaris LB
Originally Posted by RMcG View Post
If I do decide to run distilled water through the system, how long should I let the system run in order to mix & help get the older coolant out of the system? Ten minutes? 20 minutes? Until the engine is hot?
I would drive the car for a few miles, until it's warmed up, with the heat on full blast.
(I know that there is the potential problem of diluting the coolant, since you cannot get all the distilled water rinse out of the system before you add the new coolant.)
If you want, when winter approaches, you can do another quick drain-and-fill, which will reduce the dilution while also renewing a bit of the coolant. There's a very cheap and simple tool for testing the coolant dilution.
johnwk is offline   Reply With Quote
Old 07-16-2019, 02:43 AM   #2
RMcG
Drives: Yaris manufactured after 2007
Thanks John. But why is it necessary to put the heat on full blast?
R.
RMcG is offline   Reply With Quote
Old 07-16-2019, 11:27 AM   #3
johnwk
Having the heat on will make the water flow through the heater core, further rinsing out the old coolant. If the system is properly filled, the heat will stay hot through your ride. If it cools off, there's unwanted air in the system.
PS. In my experience, it takes quite a lot of "burping" the upper and lower hoses to get all the air out while filling the system. Squeeze them each slowly and repeatedly until you don't see any more bubbles at the radiator neck. And over the next week or two, double-check the levels at the radiator neck and the overflow tank. If there was air in the system that escaped, you'll need to top off the coolant.
change, coolant, engine
AT fluid change earlier than 100k miles hw6515 DIY / Maintenance / Service 25 06-06-2014 01:54 PM
HELP! Coolant is rusty brown only 30K! TheSilkySmooth DIY / Maintenance / Service 25 05-27-2010 08:26 AM
