![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
![]() Drives: 2010 Yaris LB Join Date: Jan 2019
Having the heat on will make the water flow through the heater core, further rinsing out the old coolant. If the system is properly filled, the heat will stay hot through your ride. If it cools off, there's unwanted air in the system.
PS. In my experience, it takes quite a lot of "burping" the upper and lower hoses to get all the air out while filling the system. Squeeze them each slowly and repeatedly until you don't see any more bubbles at the radiator neck. And over the next week or two, double-check the levels at the radiator neck and the overflow tank. If there was air in the system that escaped, you'll need to top off the coolant. |
| Tags |
| change, coolant, engine |
| AT fluid change earlier than 100k miles | hw6515 | DIY / Maintenance / Service | 25 | 06-06-2014 01:54 PM |
| HELP! Coolant is rusty brown only 30K! | TheSilkySmooth | DIY / Maintenance / Service | 25 | 05-27-2010 08:26 AM |
