Old 07-23-2019, 03:06 PM   #1
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
So glad you found the boost leak. That's awesome.
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 07-23-2019, 03:45 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Well, I did but there may be more areas to deal with. See above.
Old 07-23-2019, 04:07 PM   #3
The BUG plus is you actually got boost down into the usable rpm range.
Old 07-23-2019, 04:25 PM   #4
06YarisRS
Oh, for sure, WeeYari! I was so happy to see that. Now 1 - 2 psi doesn't make a huge difference, but it's definitely pulling harder. At 4 psi it's pretty strong. Once I get to my full 8, it should be even more fun!
I found this calculator a long time ago and just recently started plugging numbers in again. It is a simplified calculator, but a good reference anyway. It also seems right in line with my dyno results. Ultimately, I don't care what my numbers are as long it's working to its potential and is safe.
My Corolla engine should put out 126 crank HP stock, due to the xD (detuned, I think) ECU. With a 15% (the average, I guess) driveline loss, that would result in about 107 whp. Assuming 5.4 psi (which the tuner got, not sure how, lol), that equates to 146.32 whp. That's bang on with my dyno numbers.
At 8 psi, I should be able to expect ~165 whp. I think that should suffice in the light little Yaris, haha.
I had a long chat with a member of Toyota Nation a couple of evenings ago. He has the same kit and apparently he dyno'd 195. The kit claims to add 90 - 100 hp to the Corolla, so not sure what all is at work with mine.
Anyway, here's the very simplified boost calculator:
http://www.wallaceracing.com/hp-blower.php
It's important for me to keep my expectations in check and understand fully what this is. I've driven in muscle cars and a friend had a Porsche 930 turbo that was an under 5 second 0 - 60 car. The turbo Yaris will never be this, but it will be very fun to drive.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
