Well, I did but there may be more areas to deal with. See above.
The BUG plus is you actually got boost down into the usable rpm range.
#3 | |
I found this calculator a long time ago and just recently started plugging numbers in again. It is a simplified calculator, but a good reference anyway. It also seems right in line with my dyno results. Ultimately, I don't care what my numbers are as long it's working to its potential and is safe. My Corolla engine should put out 126 crank HP stock, due to the xD (detuned, I think) ECU. With a 15% (the average, I guess) driveline loss, that would result in about 107 whp. Assuming 5.4 psi (which the tuner got, not sure how, lol), that equates to 146.32 whp. That's bang on with my dyno numbers. At 8 psi, I should be able to expect ~165 whp. I think that should suffice in the light little Yaris, haha. I had a long chat with a member of Toyota Nation a couple of evenings ago. He has the same kit and apparently he dyno'd 195. The kit claims to add 90 - 100 hp to the Corolla, so not sure what all is at work with mine. Anyway, here's the very simplified boost calculator: http://www.wallaceracing.com/hp-blower.php It's important for me to keep my expectations in check and understand fully what this is. I've driven in muscle cars and a friend had a Porsche 930 turbo that was an under 5 second 0 - 60 car. The turbo Yaris will never be this, but it will be very fun to drive.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-23-2019 at 04:35 PM. |
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| ZPI Turbo for one lucky Yaris owner..... | ZPIracing | Forced Induction Forum | 27 | 04-26-2007 10:36 PM |
