Old 08-01-2019, 06:55 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by CrankyOldMan View Post
Sorry to hear that! It seems like my repairs are never ending as well--currently I'm going through accessory belts at an alarming rate. I've also had to replace the alternator itself three times in the last 3 years. I definitely get your frustration.
The sensor itself is a pain to remove, even with the transmission on a workbench. There's nothing to grab on to or pry against. I may have a few spares in my parts pile if you need to replace it. Getting the bolt out is going to be another story, I'm afraid. Might be able to get a welder in there and put a nut on the stub that's left, hopefully the heat will break it loose.
Hey Sam. Sorry to hear about your troubles, but I guess it's just part of our game, eh? I'm going to see if I can test the sensor on the car. I read about how to check oscillating voltages with a multimeter by supporting the car and turning the wheels. Maybe it isn't the sensor. If it isn't, I can tell you, it's not going anywhere, lol. I may be able to drill it out and tap if I do have to remove it.
If I do need a sensor, maybe I'll hit you up. That's a very kind offer! I called Toyota and they want $500.00 for the sensor. Rock Auto has one from ~$135.00, so that's always an option too.
Thanks man!
Old 08-02-2019, 08:35 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Thanks man!
Yeah, but it's mostly my own fault. I'm not as proactive about maintenance as I should be and generally let things slide until it's a crisis.
I'd be happy to donate one to the project, assuming it's the right part number!
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
