3 Yaris and counting..
Updates very soon!!
Im back wrenchin' again!! ![]() I've installed the rear axle, rear disk brake setup, ebrake cables, and braided lines where available. All from a 2012 yaris SE. ![]() ![]() So far everything has gone as planned and fits perfect except for the ebrake cables. Theres some bracketry issues. A couple of these guys need to be removed from your old cables and swapped to the new ones. Not hard. Pry them off with a screwdriver and a pry bar and squeeze onto new cables ![]() ![]() I just flattened this one to make it work
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 Last edited by myfirstyota; 09-16-2019 at 05:45 PM. |
#2 | |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| The 2zr-fe engine swap guide | ArmstrongRacing | Performance Modifications | 416 | 08-14-2023 03:14 PM |
| Aftermarket rim thread vs official wheel guide | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 04-01-2009 12:11 PM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 05:37 PM |
| engine swap?? thread deleted?? | we-to-11 | Off-topic / Other Cars / Everything else Discussions | 6 | 06-25-2007 07:34 PM |
