Old 08-02-2019, 10:55 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Pinchlite View Post
Going to paint this weekend.Using spraymax 2k.
They did not include the hardware (Screws and caps for holes)
They gave me the option to send me another or refund me 20%.
I took the refund and will figure the rest out.
SprayMax 2K is the cat's ass. Wear a good quality respirator. Those isocyanates can fark you up really bad! What are you using for a base coat? If you're using Duplicolor Perfect Match, I'd recommending applying the SprayMax clear before the Perfect Match fully cures. I cleared a set of wheels that had been base coated with the Perfect Match and had cured for a few days. The SprayMax flaked off in big sheets. I've applied the SprayMax 20 - 30 minutes after the final base coat of Perfect Match and it bonded really well and never failed.
3rd Gen Accessories: Armrest, Dead Pedal, Rear Spoiler? Lair Third Gen Yaris General Discussion 35 09-23-2017 12:54 PM
2015 yaris ....Rear Spoiler...? Eduardo_mty Cosmetic Modifications (Exterior/Interior) 2 10-14-2014 10:37 AM
Rear spoiler for the sedan?? CASTREX Cosmetic Modifications (Exterior/Interior) 19 03-26-2007 11:26 PM
