![]() ![]() Drives: Yaris Join Date: Feb 2019
what have you used to clean it ? a very mild cutting compound should be able to remove most of it if not all (you could try toothpaste)
if its on the inside pop the cluster out and remove the lens |
#2 | |
![]() Drives: Yaris Join Date: Nov 2018
Sent from my ONEPLUS A6013 using Tapatalk |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| Bumper replacement | mchamp00 | DIY / Maintenance / Service | 0 | 07-03-2015 10:45 PM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 12:33 PM |
| Reliable Source for Replacement Parts | wagon | DIY / Maintenance / Service | 4 | 03-06-2013 12:56 PM |
