Old 08-06-2019, 02:21 AM   #1
voxtrot
Drives: 2007 Yaris Sedan
Originally Posted by 06YarisRS View Post
Totally ironic. I was speaking to Costco (Canada) today and the replacement battery is $114.00 including charge of $10.00. My Kirkland battery recently crapped out. I had it tested today. It read 12.8 volts but immediately failed the draw test.
A few pics of my current one. I'll be replacing with the same. Maybe the numbers will help the Costco folks.
Thanks I was able to figure out which battery fit my Yaris. You guys in Canada get the Kirkland sticker. How long did your Costco battery last you? The batteries here have "Interstate" But pretty sure they are the same. It is interesting that I can't get that version you have in Canada. I can't believe that my Auto Zone Duralast Gold is basically the same battery as the Costco one I bought. The go up to $200! It has the same specs! Costco has such a better price and warranty for their battery.
For the folks in the states here is the battery you need if you have an older Yaris. I think they may work with Yaris up to 2016. It is basically a Corolla battery. That was the best $80 I have spent on a car battery. Lets see how long it lasts. Now I am ready for the winter.
voxtrot is offline   Reply With Quote
Old 08-06-2019, 06:52 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Mine came with the car when I bought it. The battery was from 2013 but it got drained flat a couple of times by parasitic draw which likely contributed to its demise. I don't know long it was in service before I got the car.
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove Fit, Versa and Yaris... Bought a Yaris! AlexK General Yaris / Vitz Discussion 49 09-10-2007 05:35 PM
