Old 08-26-2019, 02:13 AM   #1
komichal
Originally Posted by johnwk View Post
According to the Haynes Manual, the spec for the guide pin bolt is 34 Nm (25 ft lbs) and the spec for the caliper mounting bracket bolts is 107 Nm (79 ft lbs).
Yep, I am using these values as well. Works fine. No Loctite on threads. Waste of money (unless you have it for free).
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Rear brake disks sliding bolt torque Keymaster DIY / Maintenance / Service 6 04-12-2016 03:53 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 03:36 PM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
