Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
If the oil pan needs replaced , is there a Toyota made gasket for the oil pan.......if so , part number please. TIA
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
The oil pan doesn't have a gasket from the factory, a formed in place gasket is used which is similar to (but not the same) as RTV sealant. There are aftermarket oil pan conventional gaskets if you want to use one, FEL-PRO OS30751 or MAHLE OS32418 are a couple examples.
| Tags |
| accident, oil, oil pan, repair, service |
| Dealer oil change | boggydee | DIY / Maintenance / Service | 16 | 06-30-2010 11:21 PM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| Oil Change Issue. | Twistoffate0817 | General Yaris / Vitz Discussion | 56 | 05-05-2009 10:27 AM |
| About to do my first oil change | Kaotic Lazagna | DIY / Maintenance / Service | 32 | 01-15-2007 04:00 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
