Old 08-27-2019, 11:33 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Testing on the ECU has gone quite well, car runs just fine and does everything I need it to.
Company that does it is FTG Tuning up in Washington FTGtuning@gmail.com, if anyone wants to try and duplicate my results.
2014 BSpec Divisional Champion
Old 08-27-2019, 11:49 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I am going to send them the same questions I asked Wilson Chip Tuning. Do you think what I'm asking is possible? If I could do away with the FIC altogether, I would. Not sure if the changes to the stock ECU programming would be appropriate for a boosted (even low boost) application. Care to speculate on any of this? Thanks.
Old 08-28-2019, 12:25 AM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
I can't say it seems like a hard way to try and get a alpha N tune for part throttle. It seems like it would be easier to use the factory logic and just tune the car using that, but I don't know what kind of sensors can be integrated into the ecu.
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 02:50 AM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 10:56 AM
reflash factory ECU Brad D Forced Induction Forum 5 12-08-2009 02:40 AM
