0-60 in slow
To hats basically the reason I have the rev limiter bumped, stock cammed engine is dead around 6k so no power up top. 1nz was pretty detuned from the factory with really small cams, so there is allot to be had with certain kinds of work, if 2 zr is the same you should expect similar results.
2014 BSpec Divisional Champion |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| reflash factory ECU | Brad D | Forced Induction Forum | 5 | 12-08-2009 01:40 AM |
