![]() Drives: 07 5 door hatchback Join Date: Oct 2018
I had the same problem with my right rear sensor where the pin was broken inside the connector and the connector was broken on the side that the pin is in.
![]() After replacing the sensor and wire, I cleared the code and I now have 34, so I removed the connector and it looks fine, I reconnected it to test the sensor from inside the car and nothing, I pushed the wire out and went under the car to test the wiring and the brown wire is okay but the white one has no continuity no matter how much I try. I put a pin in the wire where it enters the connector and it is fine but inside the connector I got nothing, same procedure for the brown wire and it is fine, something is definitely not making contact inside the connector but I don’t know what or why because the wire is fine where it goes in but not in the connector. At this point I removed the wiring harness and ordered a new one but I’m still puzzled as to what could be wrong. I’m going to take a very good look at the pin in the sensor to make sure the connector inner part is not seized on the pin because I don’t want to replace the sensor if I don’t have to. Sent from my iPhone using Tapatalk |
#2 | |
![]() Sent from my iPhone using Tapatalk |
| Random Animated GIFs Thread | kimona | Off-topic / Other Cars / Everything else Discussions | 394 | 12-01-2024 06:00 PM |
| Dark's Awesome 3rd Gen Build Thread/ His General Yaris Thread. | DarkShadowFox | Third Gen Yaris General Discussion | 105 | 02-21-2019 03:56 PM |
| Does your liftback have ABS? | BensVitz | General Yaris / Vitz Discussion | 75 | 05-24-2011 07:11 PM |
| Import Alliance Thread in the General Section | tomato | Off-topic / Other Cars / Everything else Discussions | 9 | 07-12-2010 11:15 PM |
