Old 08-31-2019, 04:44 PM   #1
zrwon
zrwon's Avatar
Drives: 07 5 door hatchback
Originally Posted by zrwon View Post
I had the same problem with my right rear sensor where the pin was broken inside the connector and the connector was broken on the side that the pin is in.
After replacing the sensor and wire, I cleared the code and I now have 34, so I removed the connector and it looks fine, I reconnected it to test the sensor from inside the car and nothing, I pushed the wire out and went under the car to test the wiring and the brown wire is okay but the white one has no continuity no matter how much I try.
I put a pin in the wire where it enters the connector and it is fine but inside the connector I got nothing, same procedure for the brown wire and it is fine, something is definitely not making contact inside the connector but I don’t know what or why because the wire is fine where it goes in but not in the connector.
At this point I removed the wiring harness and ordered a new one but I’m still puzzled as to what could be wrong.
I’m going to take a very good look at the pin in the sensor to make sure the connector inner part is not seized on the pin because I don’t want to replace the sensor if I don’t have to.
zrwon is offline   Reply With Quote
Random Animated GIFs Thread kimona Off-topic / Other Cars / Everything else Discussions 394 12-01-2024 06:00 PM
Dark's Awesome 3rd Gen Build Thread/ His General Yaris Thread. DarkShadowFox Third Gen Yaris General Discussion 105 02-21-2019 03:56 PM
Does your liftback have ABS? BensVitz General Yaris / Vitz Discussion 75 05-24-2011 07:11 PM
Import Alliance Thread in the General Section tomato Off-topic / Other Cars / Everything else Discussions 9 07-12-2010 11:15 PM
