Old 09-03-2019, 11:49 PM   #1
saikouguy
Drives: Toyota Echo
Take a look at this. https://www.rigidcollar.jp/blog/2014...4%9C%E8%A8%BC/
You shouldn't really have to unbolt anything unless it you have a brace.
Best way to install it is to jack the car up on some stands and then use the jack to brace & lower the subframe abit as you back out the 4 subframe bolts far enough to slip in the collars when you remove 1 of the 4 bolts then put the bolt back in after you've installed it.
You may need a pry bar to pry the subframe for that extra clearance as it still has the rear engine mount which could cause the subframe not to lower far enough for you to slip the collar in.
saikouguy is offline   Reply With Quote
FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) Treyz Items for Sale by private party 22 04-08-2014 06:17 PM
RZCrew Garage Rigid Collars Chuckie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 02-13-2014 12:34 AM
SilkRoad NCP91 Coilovers In-Stock! Penguin Garage Penguin Garage 28 07-12-2009 05:48 PM
