Old 09-04-2019, 07:55 PM   #1
B.B._07
Drives: 07 5dr
Originally Posted by Brighton View Post
That's a pretty simple thing to address, I'll just list it to not bore you with text haha. I don't know if the models changed depending on the country it was sold in but I don't think the USDM car has a fuel filter aside from the fuel sock in the gas tank.
Should be done
  • Spark Plugs (NGK or Denso Iridium)
  • Air Filter
  • Throttle body clean
Optional to do
  • BG44k or Seafoam in next full tank of gas and get higher octane than normal
  • Marvel Mystery oil in oil prior to next oil change, idle engine for 15 mins before draining old oil
  • Upgrade to K&N or Spectra air filter
  • Heat soak engine with seafoam introduced via vacuum line after engine is hot (see instructions on can)
  • Disconnect battery for 15+ minutes so car can relearn after work is done
If by 150K you mean 150,000 KM then your original spark plugs should still be good. I would change the air filer if it's dirty, and clean the throttle body and MAF with some brake cleaner. I don't know about the quality of fuel available in Bolivia but in the US and Canada fuel filters are no longer a maintenance item since the fuel you get at gas stations is now very clean. I'm not a fan of Marvel Mystery oil and K&N air filters since the benefits are marginal or non existent in most cases.
Old 09-04-2019, 09:07 PM   #2
keith204
Drives: 2007 Yaris LB
Haha. Bolivar is a small town in Missouri. So, miles, US, and inches all apply.
Thanks for the input
Keith, 2007 Yaris Liftback
YouTube: Keith's Test Garage | http://www.KeithsTestGarage.com
keith204 is offline   Reply With Quote
Old 09-06-2019, 12:13 AM   #3
komichal
I know that some people tend to use brake cleaner on everything but it does leave a thin layer of residue which compromises the MAF functionality. At least for MAF sensor you should get MAF cleaner (which leaves NO residue). And that MAF cleaner can be used on throttle body too.
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Exhaust tips Sedan Liftback tomjasz Cosmetic Modifications (Exterior/Interior) 25 08-14-2006 06:05 PM
