Old 09-06-2019, 03:04 PM   #1
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I have removed the buzzers from both my yaris with no other issues. Its very simple actually. Grab a small screwdriver and gently pry the buzzer from the board while applying a soldering iron to the other side. Pops right out
You will however lose your headlight warning and other warnings that use the buzzer.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
DIY - Replacing the Front Seat Cushions CTScott DIY / Maintenance / Service 6 10-04-2016 06:39 PM
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 07:29 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
