Old 09-10-2019, 02:45 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
So cool to hear/see. The car looks great and I can only imagine how much more fun it is to drive over stock. Hopefully given enough time/data, you'll sort the remaining bugs, but it doesn't sound like they're all that bad.
On Instagram
On Wheelwell
Old 09-10-2019, 08:14 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yeah, it's fun for sure. I went for a long highway drive this evening and tried out the cruise control. I did get the occasional buck and sweep of the AFR gauge under a certain load and rpm. I eliminated it with the addition of some fuel, but I'm going to solder in the 2.2K resistor because it's sounding a bit like the issue the Scion cars had. Enriching the fuel map cell helps but I think I may have a little glitch in the timing around 3500 and certain other factors associated with a dirty signal. All the Boomslang harnesses have the resistors wired in.
I decided to pull a second gear WOT acceleration this evening. I poured into the throttle at about 30 kmh and the front wheels- more likely 1 wheel - lit up and spun as it entered third gear. Third is the 'funnest' gear as it pulls very hard and long, relatively speaking. I did this pull as I wanted to observe the speedometer to ensure I'm not getting any clutch slippage. The speedo jumped rapidly with tach, so I think I'm good there. This thing would kill with an LSD. It accelerates very hard once it's up over 50 - 60 kmh. Below that it wants to spin like crazy at near full boost. Although the auto is doing quite well, expect it will eventually pack it in even though I wont often be driving like I described above. If/when it dies - or starts to fail - a manual with upgraded clutch will likely replace it. I'd really like a 6-speed.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
