Old 10-08-2019, 06:11 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
There is a video here in which a guy fixes the areas to which you refer. One area that does tend to go bad is the unibody section just underneath and forward of the rear wheels. There is a small dogbone shaped stiffener that attaches in 2 spots. The contact points tend to rot out. Many Yari are scrapped as apparently it is expensive to fix. That said, anything can be fixed with time, patience and $$.
Prospective new Yaris owner Frank Necrosis New YARIS Purchase Forum 7 06-05-2012 08:38 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
