Old 10-12-2019, 01:20 PM   #1
tmontague
tmontague's Avatar
I checked out the Sport Comps. The smallest size is 195/50R15. Unfortunately this is out of spec for my factory alloys which is what I intend to keep on the car. I do actually have 195/60R15s on the car now, but there's a bit of sidewall bulge. It still handles well and the tires won't come off, I think, under extreme cornering, but it might defeat the purpose of the performance tire. A.K.A. I might not reap the benefits of such a great performance tire. Also, with the lower side wall height of the Sport Comp, the sidewall deformation might even be exaggerated.
Yeah, I might not see a lot of benefit from an LSD, and certainly wouldn't be worth the hassle and expense of installing one on this auto trans, although I believe there migh be one available. I know though that I could improve my 0 - 60 time without the amount of wheel spin I get. I'd really love get close to 6s, pipe dream, I know. I'm pretty sure that 7s might be attainable with the right launch as the car sits.
I don't remember the exact specs of the factory rims but I cannot imagine the BFG's in the above size should cause any problems even under extreme cornering. Realistically the tire will start to give way before the bead and rim do. It is only a 340tw and even though it isd a sticky 340 it will not perform anywhere close to Hoosier slicks.
a 6sec 0-60 would be pretty nuts in a Yaris, but at the end of the day it's all a balance of cost and what it would cost to do a 6sec 0-60 would likely be quite a bit. Only you can make that decision but if you don't have plans to run the car at a drag strip or race it that price can be quite steep just for the sake of knowing it can run that fast. Like I said that is a decision only you can make as the owner and person who is actually paying to do everything to the car. It would be pretty wild though
Old 10-15-2019, 07:12 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
So you're pretty convinced that I'd be ok with the Sport Comps on my 5.5" rims? Do you have any other brand suggestions for a 195/55R15 tire before I get deeped into this? I've been turning a little sharper lately and there doesn't seem to be any adverse handling even with the cheap tires I have on the car which are 195/60R15s. I think a 55 tire might improve handling a bit, especially if it had a stiffer wall. Here is a comparison between my current tires and a 55 tire. I might notice a tiny bit better acceleration as well with the slightly smaller tire diameter. What I'd really like is a 205 or 215 tire but that would definitely necessitate wider wheels.
Old 10-16-2019, 09:17 PM   #3
tmontague
tmontague's Avatar
Originally Posted by CrankyOldMan View Post
Congrats! Super stoked to see you getting back in to the groove.
The hoarder in me wants to keep those wire harnesses "just in case I need them", but good on you for sorting them out!
Thanks Sam - FWIW I have kept all of the electrical that I stripped out. plan on keeping it in a bin in case I need pins or connectors in the future. I have already used some of it when I needed wire to fix the speedometer and dash warning lights.
The BFG's should be fine on a 5.5" wide, it is at the limit but won't negate the benefit of those tires, they are fairly stiff and perform very well in wet conditions with a very predictable breakaway.
That said, I don't know if you really would benefit from shelling out cash for the tires right now if you are not finding the limits of your current rubber. They will just wear out faster than your current set up without utilising their full potential
Old 10-18-2019, 04:02 PM   #4
06YarisRS
You might be right. The tires on there now make the car handle adequately, so I may just keep them until they wear down a bit. When I replace them, I'll go for a performance oriented 55 tire. If I had gobs of cash and felt like blowing it, I'd have the factoy alloys widened an inch or and inch and a half and put a nice chunky 205 or 215 tire on there. All assuming of course that there'd be the appropriate amount of clearance with the stock offset. I'm not sure how wide a tire would have to be to start degrading performance (losing traction) on such a light car as the Yaris.
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
