3 Yaris and counting..
I'll bet 06YarisRS has over 10 grand in his setup and he's only running 7psi boost. Mind you he is 2zr swapped. But probably still 100hp short of your goals.
If you do end up building a 300hp setup, I'll be following
#2 | |
I really hope this build goes forward. I'll definitely be following it too if it does. I'm always looking at lower compression pistons, head gasket, head bolts and rods (Molnar or MWR most recently due to their lower price as opposed to Crower) in the event that I ever decide to build my engine. I've also looked at the Haltech 1500, but the ECUMaster Black looks like a cheaper, and possibly as good, alternative. Oh, and with regard to hacking the ECU, here is a response I got from ftgtuning (ftgtuning@gmail.com): #1 send me a picture of the ECU tag anf connector you are running so we can see if we have done anything with that variant before. #2 are you using the factory pressure sensor? Depending on the ECU and programming language the only way to force open loop would be with throttle control at a certain percentage (besides WOT) but without spending time working on it we cannot say for sure yet. We have done some other makes to 10-15% throttle to drop into open loop and that works well. Just to give you a heads up if we can do what you want it is going to be ~$350 for the work and we would need your ECU sent to us to do it. Before we get to that though send a picture and we can figure out what we can and cannot do for you.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 10-28-2019 at 08:08 PM. |
| 1NZ-FE All Motor Build | burned | Performance Modifications | 19 | 10-24-2014 10:56 AM |
| Carbon build up in the throttle body | Sedan | DIY / Maintenance / Service | 18 | 11-15-2013 11:44 PM |
| Tesco Horse Meat Scandal | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 23 | 02-20-2013 09:48 PM |
| How to Be a Street Racer - General Life Guide | MDF | Off-topic / Other Cars / Everything else Discussions | 7 | 03-19-2007 12:49 PM |
