Old 10-31-2019, 11:07 AM   #1
Lays
Drives: 2015 yaris L
Well nevermind, this morning I totalled my car coming home from work.
I still have some 60 treadwear advans on my car from the last autocross event a few weeks ago, I was planning on putting my normal tires on next week because it's been like low 30 degrees outside.
Rear end came out when I was coming around a corner this morning around midnight, it was 29-31 degrees, I tried to counter steer and save it but no luck.
I went through a telephone pole, a huge fence, and smacked into a giant tree.
Lays is offline   Reply With Quote
Old 01-26-2020, 11:11 PM   #2
Desircustoms
Drives: 06 Yaris RS MT
Great that you survived and are not injured!
So the rear hub bolts snapped off? Curious to know what failed exactly, I'm about to switch both rear bearings, after reading this I'll probably get some raybestos or Timken, saving a few bucks here is not worth it.
Desircustoms is offline   Reply With Quote
Old 01-27-2020, 06:04 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I think he lost traction and spun out. The normally soft/grippy tire compound was too stiff due to the cold temps.
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
Tesco Horse Meat Scandal *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 02-20-2013 09:48 PM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
