Old 11-03-2019, 01:40 PM   #9
Originally Posted by Toolaholic View Post
Test to see if exhaust gas/water leaks from joint at start up . After pipes get hot sometimes leak seals. If leak tighten some more. It’s hard to tighten with the springs on bolts. That’s why long double box wrench is used.
Not sure what you are trying to convey here. New gaskets need to get hot and melt slightly to completely seal the joint. Spring bolts purpose is to draw the flanges together as the gasket seats itself over time.
Exhaust leaking after replacing rear muffler ThinkPad DIY / Maintenance / Service 13 08-19-2017 11:21 PM
rear muffler hanger broke BobTheYaris DIY / Maintenance / Service 2 09-21-2016 05:59 PM
Muffler fell off, pipe size? shepd DIY / Maintenance / Service 4 08-28-2016 09:01 PM
Bumper replacement mchamp00 DIY / Maintenance / Service 0 07-03-2015 10:45 PM
Need Help to change Muffler sobri46 DIY / Maintenance / Service 3 02-13-2014 12:42 AM
