Old 11-05-2019, 03:03 PM   #1
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
I am no expert...but...there are weight switches mounted on the seat rail (not the pad) if I lean on my passenger seat going around Left turn, or set my loaded lunchbox on the front seat and hit a bump...I get the flashing light...beep bit...I am certain on of your switches has been "over stressed" so its telling you that someone is sitting in the seat but not buckled in... (Kinda like when a 400lb guy stands on 200lb scale...it "Bends or Detroys sensors"
if my car starts beeping, I can grab and lift under the back of the seat and make it stop...
But as I drive alone 95% of the time w/lunchbox on the seat...I just buckled the seat in from back side. LOL!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Tags
airbag, passenger seat, srs
Passenger airbag recall/disable airbag? 47_MasoN_47 DIY / Maintenance / Service 20 11-06-2016 03:36 PM
Engine Control Module Code and Rough Idle rks171 DIY / Maintenance / Service 4 05-13-2015 10:47 PM
Airbag ECU code 31 - what does it really mean? ajuniper DIY / Maintenance / Service 6 11-30-2014 09:05 AM
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 04:39 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
