#1 | |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
Add more details if possible, like total mileage of your car is very important, I experienced a similar case but thinking my yaris was new at that time just roughly 35K KM so i assume it couldn't be a clutch problem. I re-adjusted the clutch lever myself since it was adjusted by Toyota during the preventive maintenance on 30k, there was a tight tolerance "play" (feels a little engaged every time and always chatter) but after re-adjusting it everything went well and no more chattering. I also cleaned the clutch linkages and added some lithium-based lube to the pivot point and everything was smooth. |
![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
#3 | |
Does anybody have an opinion as to whether or not I have a clutch problem? Is more information needed to determine whether or not I have a clutch problem? Is there any advice you have as to what I should do at this point? Thank you, R. |
| Tags |
| clutch, problem, questionable |
| New Yaris Gearbox Problem..... | petesimla | New YARIS Purchase Forum | 22 | 04-10-2019 08:04 AM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Help: dealer might not be able to fix window problem (2012 Yaris) | matti | Third Gen Yaris General Discussion | 5 | 01-31-2013 10:37 PM |
| Yaris Clutch problem | pung | General Yaris / Vitz Discussion | 2 | 04-11-2010 03:16 PM |
