![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
Catless CEL problem
Hello, I recently did a straight pipe boom tube on my yaris and tried putting in an 90 degree o2 bung but it still shows p0420 code, anyone know of any tricks or hacks to bypass the p0420 code? thanks!
I have read about O2 simulators and they are available online but I'm not sure how well they work. I believe that Toyotas are pretty sensitive in terms of thresholds.
i saw those but im im as dumb as a rock when it comes to cutting wires and stuff
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I have a 100cell race cat and I have an angled tube feeding the O2 but with only about a 5/16" hole actually feeding it
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
what brand is your cat? you notice any piwer increase?
| CEL afer oil pressure light | andysong | DIY / Maintenance / Service | 8 | 03-06-2020 02:57 PM |
| Problem with electronic door lock | new-yaris-owner | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-05-2012 05:12 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
