Old 11-29-2019, 03:48 PM   #11
myfirstyota
3 Yaris and counting..
I've only seen the end of lifespan of 2 clutches. Usually, you will experience slipage under heavy load. At that point it can usually still be limped around for a couple hundred km keeping I mind to be easy on it. I doubt you'll have a complete failure leaving you stranded.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Tags
clutch, problem, questionable
New Yaris Gearbox Problem..... petesimla New YARIS Purchase Forum 22 04-10-2019 09:04 AM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 11:42 AM
Help: dealer might not be able to fix window problem (2012 Yaris) matti Third Gen Yaris General Discussion 5 01-31-2013 11:37 PM
Yaris Clutch problem pung General Yaris / Vitz Discussion 2 04-11-2010 04:16 PM
