Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Wonder how much there would be different swapping one of these into a 12-14 Yaris..
All of the ones I've seen are done using 06-11 cars.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
#2 | |
![]() To your point, later in the video they made mention of "the internet" being right or wrong several times, so I'm sure they spent plenty of time here doing their homework. Nonetheless, this is part of the "Yaris" attention I was referring to in the few posts about the site crashing and decaying. Seems the 06-11 cars are easiest because you won't run into some of the immobilizer issues they did. |
Gen 3 > Gen 2
I wonder if you can get around that issue like MCM did by sticking the Corolla key near or attached to the transponder in the steering column. It'd be crude but it would get you running.
#4 | |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
1. Bridge pins 4 and 13 of the OBDII connector 2. Insert an existing key into the ignition and switch the ignition on and then leave for 30 min 3. Turn the ignition off and remove the bridge from pins 4 and 13 4. Start the car Here's the procedure being performed on a Lexus ISF https://www.youtube.com/watch?v=QocuEYNE6KM atomic_hoji on this forum performed the same procedure on his Yaris 2zr conversion with success. http://www.yarisworld.com/forums/sho...2&postcount=36 |
![]() Drives: 2000 3dr LB Join Date: Dec 2018
Australian models have transponder keys , you can just cut the chips out the key . Easy to get an new transponder key cut and programmed if the key that came with ecu is the MASTER key
| Engine turns over but doesn’t start on a Yaris VVTi | YarisVVTi2002 | DIY / Maintenance / Service | 50 | 03-30-2025 08:27 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
