Old 12-30-2019, 12:33 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Originally Posted by CrankyOldMan View Post
About damned time! I was a bit disappointed in the overall tone of "there are rumors on the internet that it's possible" or "we don't know if it will work" when there are at least half a dozen confirmed builds on this forum alone, most of which are excruciatingly detailed and list what parts you need to make it happen...
Yeah, I saw it and couldn't agree with Cranky more. I didn't buy any of the fake coy acting about not knowing if it can be done. It's been done many times by our friends here
To your point, later in the video they made mention of "the internet" being right or wrong several times, so I'm sure they spent plenty of time here doing their homework.
Nonetheless, this is part of the "Yaris" attention I was referring to in the few posts about the site crashing and decaying.
Originally Posted by mitch9521 View Post
Wonder how much there would be different swapping one of these into a 12-14 Yaris..
All of the ones I've seen are done using 06-11 cars.
Seems the 06-11 cars are easiest because you won't run into some of the immobilizer issues they did.
On Instagram
On Wheelwell
Old 01-01-2020, 01:12 AM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I wonder if you can get around that issue like MCM did by sticking the Corolla key near or attached to the transponder in the steering column. It'd be crude but it would get you running.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Old 01-01-2020, 02:52 AM   #3
stidnam
Drives: Starlet
Or you could try the official Toyota procedure to register a new ECU with the immobiliser computer. Goes something like this.
1. Bridge pins 4 and 13 of the OBDII connector
2. Insert an existing key into the ignition and switch the ignition on and then leave for 30 min
3. Turn the ignition off and remove the bridge from pins 4 and 13
4. Start the car
Here's the procedure being performed on a Lexus ISF
https://www.youtube.com/watch?v=QocuEYNE6KM
atomic_hoji on this forum performed the same procedure on his Yaris 2zr conversion with success.
http://www.yarisworld.com/forums/sho...2&postcount=36
stidnam is offline   Reply With Quote
Old 02-05-2020, 08:26 PM   #4
Ausecho
Drives: 2000 3dr LB
Australian models have transponder keys , you can just cut the chips out the key . Easy to get an new transponder key cut and programmed if the key that came with ecu is the MASTER key
Ausecho is offline   Reply With Quote
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
