Old 01-08-2020, 11:05 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by mannycheckers View Post
All valid points. I don't have a boosted Yaris, I don't race or autoX, nor do I care about customization of displays, so I don't need to get accurate data. For my current use case, I just wanted to view water temperature, RPM, and a digital speedometer.
The chinese stuff does what I need it to, and the banks gauge would be overkill for my needs, and that's why I thought the price was high. However, if the one banks gauge replaces your gauge cluster, then I can definitely see the value.
For sure. In my opinion the Chinese gauges are actually good value for the money. Hell, I was buying temp gauges for $15.00 bucks a pop and they worked fine. I may have been a bit harsh about their accuracy. I've seen them perform as well as some medium priced gauges. Higher end ones are not always necessary. I had to go with an expensive AFR gauge with a quality wideband sensor to get accurate ratios as the life of my engine depends on it. Most of my Prosport gauges are lower end, not very expensive and will probably require sensor replacement in the not too distant future. I purposefully ordered 2 extra oil pressure sensors as that will likely be the first to go. Had I had the budget, would I have bought the AEM or Defi gauges? Unquestionably!
Anyone put in gauges into radio location? end user DIY / Maintenance / Service 2 03-18-2016 11:50 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
check engine light twice within a week of purchase?? conurebuddy General Yaris / Vitz Discussion 8 04-17-2009 10:53 AM
Paying for the Yaris with a check? YotaYarisUSA New YARIS Purchase Forum 15 07-11-2007 03:31 PM
