Old 01-20-2020, 04:47 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Great to see that you've got a place to wrench again! I put an electric heater in my garage this fall as well. It's not cheap but it means I can work out there whenever I want.
As for weight reduction, I think you've nailed all of the really important parts. Some of the parts are going back in for safety/convenience, so be careful what you cut out. I've been tagged in the head more than once by the trunk lid slipping off the broom stick that holds it up since the springs are gone and the edges of the door interiors are a little questionable in some spots. The front bumper beam and supports were not installed when I got mine but those have gone back on for protection of the radiator and some low-speed collision safety.
Old 01-21-2020, 02:58 PM   #2
tmontague
tmontague's Avatar
thanks Sam, I'll keep that in mind when removing things. I don't think there is a lot more I can strip out but we will soon find out
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
