Originally Posted by Desircustoms
Great that you survived and are not injured!
So the rear hub bolts snapped off? Curious to know what failed exactly, I'm about to switch both rear bearings, after reading this I'll probably get some raybestos or Timken, saving a few bucks here is not worth it.
I think he lost traction and spun out. The normally soft/grippy tire compound was too stiff due to the cold temps.
