Old 02-05-2020, 01:15 AM   #1
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
It didn't sound healthy.
They kept mentioning the $169 turbo, but never mentioned the cost of the Haltech ECU.
Old 02-05-2020, 02:32 AM   #2
stidnam
Drives: Starlet
lol that it did not. I wonder if they found the limit of a 2zr :)
stidnam is offline   Reply With Quote
Old 02-05-2020, 05:50 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I sure hope that's not the limit. But it was an older engine and you never know what shape it was in originally. I can't see the failure being caused by the Haltach technician. Surely those guys could see detonation coming before it occured. I'd love to see the dyno sheet if it had info on AFR.
Old 02-05-2020, 09:14 AM   #4
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
Haltech is probably free or very discounted for them.
eBay turbos aren't always bad, but one that cheap is destined to fail. Check out the turbos that the BoostedBoiz and PFI Speed are using from ebay. Several cars making 1000whp with honda K series and ebay turbos pretty reliably.
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
