Old 02-05-2020, 03:32 AM   #1
stidnam
Drives: Starlet
Originally Posted by kevinj93 View Post
It didn't sound healthy.
They kept mentioning the $169 turbo, but never mentioned the cost of the Haltech ECU.
lol that it did not. I wonder if they found the limit of a 2zr :)
stidnam is offline   Reply With Quote
Old 02-05-2020, 06:50 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I sure hope that's not the limit. But it was an older engine and you never know what shape it was in originally. I can't see the failure being caused by the Haltach technician. Surely those guys could see detonation coming before it occured. I'd love to see the dyno sheet if it had info on AFR.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 05:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 11:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 09:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 10:12 AM
