Old 02-05-2020, 11:42 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's probably not the limit of the 2ZR. Lotus runs the Series 3 Elise up to 186 kW (at the crank) with a supercharger. I'm pretty sure they wouldn't ship production vehicles at the ragged edge of performance. =)
Old 02-05-2020, 04:37 PM   #2
stidnam
Drives: Starlet
Surely Lotus would be not be using off the shelf 2zr motors though. I'd love it if they are as point proven, but surely not if punching out 186kw in a track car.
stidnam is offline   Reply With Quote
Old 02-07-2020, 06:02 AM   #3
Ausecho
Drives: 2000 3dr LB
Lotus uses the 2ZZGE motor with VVTLi , different motor .
Ausecho is offline   Reply With Quote
Old 02-07-2020, 06:49 AM   #4
stidnam
Drives: Starlet
Will just leave this here for you ;)
https://en.wikipedia.org/wiki/Lotus_Elise#Cup_260
Old 02-07-2020, 08:17 AM   #5
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yes, I've shared that !ink a few times too. A lot of people seem to be convinced that only the 2ZZ was used.
Old 02-07-2020, 01:57 PM   #6
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
2011+ Elise use the 2ZR-FE with a blower.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Old 02-09-2020, 08:01 AM   #7
benoityip
Drives: Corolla 1.8
I don't think lotus change the motor, they even keep the stock exhaust header, which is very restricted
benoityip is offline   Reply With Quote
Old 02-11-2020, 05:02 AM   #8
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
MCM posted a new video today. The bad knocking noise was the Air Conditioning compressor.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
