Old 02-07-2020, 06:02 AM   #1
Ausecho
Drives: 2000 3dr LB
Lotus uses the 2ZZGE motor with VVTLi , different motor .
Ausecho is offline   Reply With Quote
Old 02-07-2020, 06:49 AM   #2
stidnam
Drives: Starlet
Will just leave this here for you ;)
https://en.wikipedia.org/wiki/Lotus_Elise#Cup_260
stidnam is offline   Reply With Quote
Old 02-07-2020, 08:17 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yes, I've shared that !ink a few times too. A lot of people seem to be convinced that only the 2ZZ was used.
Old 02-07-2020, 01:57 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
2011+ Elise use the 2ZR-FE with a blower.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
