Old 02-18-2020, 08:13 PM   #1
tmontague
tmontague's Avatar
My opinion: keep the 0w40 Euro for your Euro car. Run the proper 0w20 on your 2zr, there is absolutely nothing to be gained but running the 0w40 in your 2zr.
Somewhere in my past posts was info about me (incorrectly) running a 5w30 in my 2zr on track due to high coolant and oil temps. 0w20 actually dropped my oil temps (as it should) and I never came close to being outside the specs for oil pressure put out by Toyota.
The only way going up in weight makes sense is if you are putting the engine oil outside of it pressure specs. Temp isn't the issue, pressure is and pressure is a product of temp and dependent on the specs of the oil pump.
There are many race teams who have dyno'd MOAR POWAAH running 0w20 then on thicker oils.
I have spent way too many days reading studies and forums to satisfy my empirical brain to convince me of what oil to run. Spoiler alert: much of what you hear at the track that is old info passed down is no longer relevant with today's oil and is often just outright incorrect...needing to run a thick oil is one of them and needing to drain oil after every track session is another.
Old 02-26-2020, 04:48 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Good enough for me. Will stick with the 5W20 and monitor oil pressures. I doubt my 2ZR will ever get as hot as yours as I don't track it. Thin is in!
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
