Old 03-14-2020, 09:23 PM   #1
la_scanner
Drives: 2007 toyota yaris
Hi again...
Okay, so I swapped #2 with #4. I got on the freeway, sped up several times and on the way back home the check engine light came on. Actually, right when it went on I felt the vehicle lose power. It's neat to see this first hand.
Being that the spark plugs have less than 30,000 miles on them, I think I should be able to get away with only replacing the coil? What do you think?
Amzon has the coil for what I believe is a great price. $54 https://www.amazon.com/Denso-6731306...832011&sr=8-14
la_scanner is offline   Reply With Quote
Old 03-15-2020, 06:43 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Originally Posted by la_scanner View Post
Hi again...
You can replace the defective coil and you're good to go. but if i were you, you may replace the plugs too, they are cheap and it pays to replace them too. Manual says you can go up to 160k KM or 100K miles.
Where i sent my car previously (under warranty) they replaced them every 20K KM (at Toyota Service Center) and i happened to ask the mechanic about it. He said what is in the manual is if you are running normal RPM but in Saudi we average at 120-140kph at 3500-4000rpm since we usually drive on a freeway hence the need to change them earlier than required.
Right now i do my maintenance and replace plugs by myself at around 30-40K KM interval...
rayfloyd170 is offline   Reply With Quote
Old 03-15-2020, 11:56 AM   #3
That is pure BS. Someone is making easy money off of you wasting yours.
Old 03-15-2020, 12:03 PM   #4
You didn't indicate if the code has now moved to cylinder 4. Has it?
Old 03-16-2020, 02:59 AM   #5
la_scanner
It's still showing the same code of P0302.
Tags
coil, maf, p0302, spark plugs
Misfire cylinder 3-4 yaris 2007 vandammages DIY / Maintenance / Service 0 05-09-2017 08:57 PM
Cylinder 1 misfire and catalytic converter issue Lu Xun DIY / Maintenance / Service 3 08-24-2013 06:37 AM
Misfire into multiple cylinder! maxthehax Forced Induction Forum 21 12-12-2012 12:18 PM
P0300 Random / Multiple Cylinder Misfire DetectedCylinder 3 misfire dante2086 DIY / Maintenance / Service 4 05-15-2011 04:36 PM
