Old 03-16-2020, 03:52 PM   #1
la_scanner
Drives: 2007 toyota yaris
Okay, thanks for getting me this far. I better ask though, was I supposed to switch any thing with the plug/wires? I don't think I would have been able to anyway, too short to move around.
la_scanner is offline   Reply With Quote
Old 03-17-2020, 08:28 AM   #2
No.
Just a thought. Did you count off the cylinder position correctly? Standing in front of car, looking at the engine, cylinder 1 -> 4 from left to right. I'm sure you got it right but need to be sure.
Old 04-05-2020, 02:46 PM   #3
la_scanner
No.
That's a fair question, they were labeled, so no issue there. I had called the mechanic and asked how they came to the diagnosis they gave. He told me they first swapped coils and that it threw a different code and that they tested with a multimeter to confirm it was damaged. I knew this was BS because it gave me the same code when I swapped the coils. It gave me the same code when replacing the "damaged" coil. Still throws the code after installing new Denso spark plugs as well.
Something else I think is fair or would be fair is for me to take the car to Toyota, let them fix it and bill the mechanic who charged me for this diagnosis and for the trouble it has caused me.
Tags
coil, maf, p0302, spark plugs
Misfire cylinder 3-4 yaris 2007 vandammages DIY / Maintenance / Service 0 05-09-2017 08:57 PM
Cylinder 1 misfire and catalytic converter issue Lu Xun DIY / Maintenance / Service 3 08-24-2013 06:37 AM
Misfire into multiple cylinder! maxthehax Forced Induction Forum 21 12-12-2012 12:18 PM
P0300 Random / Multiple Cylinder Misfire DetectedCylinder 3 misfire dante2086 DIY / Maintenance / Service 4 05-15-2011 04:36 PM
