The only difference is the RS came equipped with beefier tires. No changes to stock suspension or steering ratios and feedback over the CE/LE.
#2 | |
![]() Drives: 2007 yaris Join Date: Dec 2018
Not very clear for me yet !
I have on my '09 LE the RS rims with 185 tires from my first '06 RS - for summer driving - ... if there's a difference from switching the winter tires 175 on steelies with 15' summer alloys , then it's very minimal as I don't feel any difference ! The difference is handling was clearly in my case : 07 RS vs 09 LE. Obviously it wasn't a difference like BMW 3er vs LEXUS/TOYOTA but it was kinda of a difference '06-'07 Accord vs '05 Camry SE or almost such a difference . I have had 2 Accords , '06 2.4L manual and '07 V6-6speed . Maybe I got a stiffer than normal steering on my '07 RS . A too old power steering fluid cannot be to blame for that as our cars have an electric power steering Wonder if adding a rear sway bar will make me feel my actual LE like the old '07 RS ; at least in tight turns less body roll as steering obviously won't change Like a minor adnotation , it seems that my Yaris LE engine started to break it. With my previous RS cars and the actual LE until a few months ago my summer fuel economy used to be between 5.6 and 6.2 l per 100km. Always checked very accurate by overfilling the tank up to maximum allowed . Winter was usually between 7 and 8l/100km depending on the quantity of snow and temperature. The actual 'new reality' with much less cars on the streets cannot be blame for my newer fuel economy as I noticed a clear improvement about 4 months ago when the old normality was in place. Starting with FEB I started to have fuel economy of around 6l/100km which was unusual for winter time. Then I constantly got under 6l/100km although the temps were around 0C . The engine had 210k at that time. My last fuel economy recorded was a new 'personal best' :)) : 5.4l/100km so 43.5 mpg beating my old personal best of 5.6l/100km which I recorded it for several times. So apparently this Yaris engine broke in after 210,000 km. The old Yarises were sold with 200k respectively 150k on odometer . So far I always wanted to have a lower car mileage to be sure about the reliability in the field of deliveries but having for so many years Yarises I realized that my fears were not realistic. Instead of paying more for low mileage Yaris I am gonna keep this car forever as apparently the fuel economy is improving , there are virtually almost no bad things which can happen - maybe the starter will fail one day as it happened to my RS at 170k but back then I was at the beginning and I was turning off the engine more often - , oil consumption is next to nothing at 300-400 gr for 10,000km always using syntetic - Plus that the clutch - LUK , german brand - replaced at 170k still feels like new after 55k+ done and definitely better , springier than the original one. for this amazing reliable little city car !
#4 | |
100% Steering ratio is different in RS vs the LE ! At least in my 2 cases , 3 years ago and ... today comparison ! The difference is VERY CLEAR ! RS is a much more enjoyable car |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I'm not sure about Gen 1 or 2, but there are definitely 2 different steering racks for the Gen 3.
The Australian version is listed with a different steering ratio to the rest of the world. Australia lists as 1:12.8 ratio, with 2.69 turns lock to lock. The other listing says 1:14.3 ratio, with 3.02 turns lock to lock. There are also slightly different wheel alignment settings listed for different tyre sizes.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| License Plate question | awebb005 | Cosmetic Modifications (Exterior/Interior) | 5 | 11-11-2014 08:28 AM |
| handling question | jpoy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 04-08-2009 11:26 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| Question for the audio guys.. | vacantj | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 09-23-2007 11:40 PM |
| Question??? Improving handling on a sedan | CASTREX | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 12-06-2006 01:19 AM |
