Old 04-17-2020, 07:26 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
The only difference is the RS came equipped with beefier tires. No changes to stock suspension or steering ratios and feedback over the CE/LE.
Well, there we have it. Thanks, WeeYari.
Old 04-19-2020, 09:15 AM   #2
radu1976
Drives: 2007 yaris
Not very clear for me yet !
I have on my '09 LE the RS rims with 185 tires from my first '06 RS - for summer driving - ... if there's a difference from switching the winter tires 175 on steelies with 15' summer alloys , then it's very minimal as I don't feel any difference !
The difference is handling was clearly in my case : 07 RS vs 09 LE.
Obviously it wasn't a difference like BMW 3er vs LEXUS/TOYOTA but it was kinda of a difference '06-'07 Accord vs '05 Camry SE or almost such a difference . I have had 2 Accords , '06 2.4L manual and '07 V6-6speed .
Maybe I got a stiffer than normal steering on my '07 RS .
A too old power steering fluid cannot be to blame for that as our cars have an electric power steering
Wonder if adding a rear sway bar will make me feel my actual LE like the old '07 RS ; at least in tight turns less body roll as steering obviously won't change
Like a minor adnotation , it seems that my Yaris LE engine started to break it.
With my previous RS cars and the actual LE until a few months ago my summer fuel economy used to be between 5.6 and 6.2 l per 100km. Always checked very accurate by overfilling the tank up to maximum allowed . Winter was usually between 7 and 8l/100km depending on the quantity of snow and temperature.
The actual 'new reality' with much less cars on the streets cannot be blame for my newer fuel economy as I noticed a clear improvement about 4 months ago when the old normality was in place.
Starting with FEB I started to have fuel economy of around 6l/100km which was unusual for winter time. Then I constantly got under 6l/100km although the temps were around 0C .
The engine had 210k at that time.
My last fuel economy recorded was a new 'personal best' :)) : 5.4l/100km so 43.5 mpg beating my old personal best of 5.6l/100km which I recorded it for several times.
So apparently this Yaris engine broke in after 210,000 km.
The old Yarises were sold with 200k respectively 150k on odometer .
So far I always wanted to have a lower car mileage to be sure about the reliability in the field of deliveries but having for so many years Yarises I realized that my fears were not realistic.
Instead of paying more for low mileage Yaris I am gonna keep this car forever as apparently the fuel economy is improving , there are virtually almost no bad things which can happen - maybe the starter will fail one day as it happened to my RS at 170k but back then I was at the beginning and I was turning off the engine more often - , oil consumption is next to nothing at 300-400 gr for 10,000km always using syntetic -
Plus that the clutch - LUK , german brand - replaced at 170k still feels like new after 55k+ done and definitely better , springier than the original one.
for this amazing reliable little city car !
radu1976 is offline   Reply With Quote
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 08:28 AM
handling question jpoy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-08-2009 11:26 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
Question for the audio guys.. vacantj In Car Entertainment + Electronics (audio / video / alarm) 3 09-23-2007 11:40 PM
Question??? Improving handling on a sedan CASTREX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-06-2006 01:19 AM
