![]() Drives: scion xb Join Date: Apr 2020
the prius C engine is the one to use to make any substantial 'gains'. the original prius 1.5l engine is basically identical internal except for pistons. you can swap pistons to the yaris 1.5l, or swap yaris cams to the original prius engine.
the prius c engine has newer designs on some of the problematic 1nz issues (valve stem seals come to mind) but it requires 'some work' to install. i have a write up on an install in a 1st gen scion XB, i will post some. |
| forged 1nz turbo build | 1nz_tommy | Performance Modifications | 2 | 10-22-2014 08:40 AM |
| 1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods | jtw11 | Performance Modifications | 8 | 09-03-2013 01:49 PM |
| Forged Pistons, connecting rods, piston rings etcetc | mastaofdisasta | Performance Modifications | 2 | 04-18-2010 12:05 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| GI: 1NZ-FE Forged Rods | Nexus1155 | Forced Induction Forum | 41 | 03-21-2009 03:29 AM |
