GR yaris is basically using a scion xd setup for 5lug.
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
The hunt for 5 X 114.3 PCD continues...
Yaris rear wheel hub...
Yaris rear hub.jpg 2nd GEN Scion xB rear wheel hub (5 x 114.3)... 2nd Gen Scion xB rear hub.jpg Interesting... Adding this to my "To Do" project. |
#4 | |
NO NO NO NO bad...im staying true to my 4x100...but the 1st gen toaster XB that will be soon.....hmmmmmmmm |
#5 | |
![]() Yes, my theory is that the 2nd GEN xB (xB2) also uses the Yaris/xD rear axle frame. If so, then the hunt for the Yaris SE rear axle frame stops and pursue looking for the 2nd GEN xB’s axle frame for rear disc conversion!!! The front spindle for the xB2 are already pressed in the bearing, they do have the same spine count (26), and I think if you press them out, they’ll fit in the Yaris’ front bearings. I should ask my neighbor if I can take measurements of his 2nd Gen xB. |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Catback exhausts and rear disc brake conversions | eTiMaGo | Performance Modifications | 59 | 01-04-2009 06:13 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-25-2007 11:10 PM |
