Old 04-26-2020, 11:51 AM   #1
woops
Drives: Jeep Cherokee XJ 1996
Good job but sir, please get a pair of proper jackstands, infact get 4x of them, they are cheap - reliable and small enough to not take too much space.
woops is offline   Reply With Quote
Old 04-26-2020, 09:14 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks. Actually I do have 4 jack stands. A couple of them are 5 ton stands. My car lived on them while I did the swap and then the turbo kit. For quick jobs like oil changes, inspections and trans fluid drain etc. I just jack up and block under the tires with 4 x 4s. Normally, I would crib two levels of three blocks for a total of 6 per wheel, but this time I only used 4, each side. Even if the jacks failed, the car would only drop a couple inches.
FS: COMPLETE turbo kit for yaris 0BD1Kenobi Items for Sale by private party 41 03-15-2016 11:33 PM
Used Oil Analysis - Yaris '08 144,000km tmontague DIY / Maintenance / Service 10 10-30-2015 12:26 PM
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
