Old 04-26-2020, 11:34 PM   #1
Originally Posted by bentjazz View Post
Thanks, KL. Okay, don't laugh or shake your head. But where's the fill plug?
Originally Posted by komichal View Post
Here is a nice tutorial: https://www.yarisworld.com/forums/showthread.php?t=8912
No need for a fancy filling tool for this job. A funnel with a piece of hose will do just fine (filling from top).
If you decide to change the oil then use only original Toyota. Multiple people (including me) had multiple issues with quality non-original oils (Mobil 1, Valvoline,...) despite their full conformity with the specs.
Great guide to follow. Only thing I'd add, which I mentioned already, is to replace the gaskets/washers with new ones. So if you do replace the trans fluid, order the gaskets in advance (they're way more expensive at a dealership).
I just use a cheap fluid transfer pump for my transmission and diff (for the FR-S) fluid/oil changes.
The Yaris seems to like Amsoil, but in the FR-S, it shifts smoother with the Toyota/Subaru lube.
Automatic Transmission Fluid - Drain and Fill vinny121 DIY / Maintenance / Service 5 04-07-2022 06:48 AM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Transmission oil? jamesxl DIY / Maintenance / Service 3 04-11-2016 10:18 PM
transmission fluid that indicate must change susucosp DIY / Maintenance / Service 3 12-10-2011 11:51 PM
