Old 04-30-2020, 05:30 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
As I said on the 'gram, I dig it.
Interesting that Kimona favors the darker, but doesn't like black wheels. I have black wheels, but as I commented to you on Instagram, think a shade or two lighter would work even better.
Beauty is in the eye of the beholder!
On Instagram
On Wheelwell
Old 04-30-2020, 10:03 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Absolutely! A couple shades lighter would have been preferable. I still think black wheels would look good on my car. If the paint fails on these wheels - chips or doesn't generally wear well and they get unsightly - I'll repaint them with a single stage urethane and may go with graphite. I really think that graphite would look great against the silver.
Edit: I'm actually thinking about applying a 2K clear coat over these wheels. It is advised against - being a 1K enamel - but if I dust 2 to 3 coats on and let them flash off, I might get away with heavier coats after that. I actually sprayed a little clear coat on one of the playing cards that had over spray on it. There was no adverse reaction. I'll give the wheels a couple of weeks to cure fully if I go ahead with this.
Old 05-04-2020, 02:51 PM   #3
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 12:19 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
