Old 05-08-2020, 05:24 PM   #1
LeBnomiS
Drives: 2011 Yaris 3DHB
Well, after changing the plugs, the PCV valve, and cleaning the mass air sensor, I found the rattle to be the exhaust manifold heat shield, lol ! The bolts on the bottom practically turned to dust when I tried to tighten them. I'm going to try to tie it down with a hose clamp.
We'll see if the new plugs and the clean sensor will do the trick for the misfire problem.
LeBnomiS is offline   Reply With Quote
