Old 05-11-2020, 01:13 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by CrankyOldMan View Post
McMaster is good like that--basically overnights stuff to me if I order early enough in the day.
Good catch on the check valve. The highest cracking pressure I could find on McMaster was 4 psi and they were all crazy expensive. Any chance you can disassemble the valve you got and put in a stronger spring? You'd have to find the right one by trial and error, not sure if you can get a selection of springs locally or if you'd have to try and order a bunch from McMaster.
I frickin' love MaMaster-Carr! Amazingly friendly service, great prices, huge product selection, knowledgeable staff (from my first experience). And, yeah, that shipping time...awesome! From my limited experience, it seems they set the bar.
Actually, I think the check valve is going to serve it's purpose in this way. The water solenoid will protect against unwanted injection when the engine is running, the check valve will keep fluid from heading toward the motor when the engine off. I think the crack pressure of this valve is only about 1 psi. I also wonder how much vacuum is on the intake side of TB butterfly at idle. Maybe enough to siphon, but, again, I'm hoping that the solenoid gate valve looks after that. The above said, I plan to test the system extensively before it gets operated on the car. This is SO much fun!!! Haha. BTW, I'm pretty sure that typical water/methanol check valves are in the 16 to 20 psi crack range. My pump only does 80, haha, so it should be interesting to see what kind of pattern and volume I get out of it.
Question for you, Sam...
Since I'm not looking to gain any power here - simply provide a higher effective octane number - in your opinion, is any amount of water injection helpful? For example, if I couldn't meet the full recommendations of load/boost etc water volume, would lesser amounts still help to some degree? I'm not sure that it's a truly linear relationship, or if there is some kind of minimum needed to have any effect.
Old 05-11-2020, 05:15 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Since I'm not looking to gain any power here - simply provide a higher effective octane number - in your opinion, is any amount of water injection helpful? For example, if I couldn't meet the full recommendations of load/boost etc water volume, would lesser amounts still help to some degree? I'm sure it's a truly linear relationship, or if there is some kind of minimum needed to have any effect.
That's all way out of my wheelhouse. I've never done tuning before, just slapped the Blitz on my 1NZ and called it a day.
Old 05-13-2020, 08:19 PM   #3
06YarisRS
Yeah, well I'm learning a lot. It's interesting, but sometimes I wish it was simpler. Haha.
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Water Injection Toy_Yoda Forced Induction Forum 3 05-04-2013 09:20 PM
FS: Blitz Supercharger + AEM Water/Methanol Injection Kit fmicle Items for Sale by private party 22 03-08-2013 01:46 AM
FS: AEM Water/Methanol Injection Kit fmicle Items for Sale by private party 0 02-19-2011 01:59 AM
